Possible make constraint to other sketch without project geometry?
glenncai
glenncai
Can I collinear line between 2 different sketch? It look's like  I can't select from the other sketch with constraint command. I do not want project an extra line into the frame sketch because that will complicated the line selection when using frame generator. Thank you!
johnsonshiue
Hi! Unfortunately, projection is the only way. You can turn the projected line as a construction line so it is not that prominent.
Many thanks!
Software Test Engineer
Sam10001
Or perhaps just project the corner point.
