Hello everyone!
Im new here and new to designing in inventor and I'm looking for information ๐ Is it possible to set a normal distance between a measurement and the geometry when im placing my measurements in a drawing? I want the closest to be 12mm and after that +10mm. If there is no settings for this, is it possible to set it up accurate by hand or do i need to eyeball it?
Here is a example off what i mean:
Solved by CGBenner. Go to Solution.
Solved by pcrawley. Go to Solution.
You sure can. Open your template drawing and look in Manage > Styles Editor > Dimension:
Variables D and E will do what you are asking.
โ
@pcrawley Dude, you beat me by about ten seconds.... ๐
Chris Benner
Industry Community Manager โ Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
