- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi again. Does Inventor allow me to position a single hole, that will be used as the initial/starter hole for a hole array relative to the centre of an existing hole with x and y coordinate values - similar to the hole array on a flange that has the centre hole for the pipe to go through and then has the bolt hole array around it relative to the centre of the pipe hole? I can obviously extrude the hole pattern but that doesn't (or it didn't when l tried it) let me dimension the hole pattern using the Hole and Thread Notes dimensioning function. I am trying to create an equi-spaced 4-hole array about the centre point of an existing hole but am wanting to avoid having to lay down a sketch in order to position a point relative to the centre hole that will be the starter hole for my array. If this doesn't exist might Autodesk look at creating this function as l think it would be beneficial? Thanks, as always.
