Inventor Forum
Porcupine Element
7 REPLIES 7
Message 1 of 8
San-Teknik
1138 Views, 7 Replies
Porcupine Element
Hi
I'am going to make a porcupine heating element( search in Google) I know i need a lot of plane, but can't finde the right solution.
I need to change the parameters for the increase, and the angel
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: San-Teknik
@San-Teknik wrote:
...( search in Google)
Can you do the Google search for me and attach direct link here?
Can you attach Inventor file of your attempt here (what version of Inventor are you using)?
Message 3 of 8
San-Teknik
in reply to: JDMather
I have attachment a foto of the element og our file mede in Inventor 2017
Message 4 of 8
johnsonshiue
Hi! It does not have to be this difficult. It looks like you are on Inventor 2017. I am attaching an image showing how to wrap a line around a rounded triangular surface. The 2018 part is also attached. You should be able to do that in 2017.
Many thanks!
Software Test Engineer
Message 5 of 8
JDMather
in reply to: johnsonshiue
Hmm, I gave this a bit of thought and think it might be slightly more complex than a wrap around a single triangle.
But it is definitely a pattern and can therefore be significantly simplified.
Message 6 of 8
kelly.young
Hello @San-Teknik thanks for the interesting post!
Not sure of the final intent, but I just drew 1/12th of the line, inserted into assembly and constrained 12 times, then patterned at the Height*12.
I couldn't think of any pattern commands that would speed this up.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 7 of 8
San-Teknik
in reply to: kelly.young
Thanks for the part and assembly, that is eactly what i was looking forSmiley Happy
Message 8 of 8
San-Teknik
It's not only about a triangle it's supposed to run.
See answer below. thanks for your attempt.
Technology Administrators
