Pop-up "Autodesk Inventor Professional Tips"
m.gronouwe
m.gronouwe
Hi, one of my students sees in autodesk inventor the pop-up screen "Autodesk Inventor Professional Tips" with a fresh tip, every time  he tries to draw a solid, using the sweep command. Does anyone know how to turn off these tips?
Mark.Lancaster
@m.gronouwe
Are you referring to the tool tips that are under Tools/Application Options/General tab?
Mark Lancaster
johnsonshiue
Hi! I think you are talking about the cascading tooltips on Ribbon panel, right? It can be turned off in the following dialog.
Go to Tools -> Application Options -> General -> Tooltip appearance -> uncheck "Show document tab Tooltips."
Many thanks!
Software Test Engineer
