Inventor Forum
point to point measurement on flat surface
4 REPLIES 4
yefimv
336 Views, 4 Replies
Hello,  i have a flat surface  a rectangular shape filled with holes.
I need in drawing mode to show measurments from an edge of rectangulat to center of some circle inside it.
so i will get the vertical distance and horisontal distance between them.
Is there some manual that could help me?
Thanks.
4 REPLIES 4
JDMather
in reply to: yefimv
@yefimv
Can you Attach your file(s) here?
yefimv
in reply to: JDMather
Hello, sorry i dont have the file currently but as shown in the photo below, i  want to do in drawing mode vertical distance between  the red dot and the blue dot.
and horizontal distance between the red dots.
Is there some manual that could help me in showing such distances as shown bellow?
Thanks.
The_Angry_Elf
in reply to: yefimv
Please tell me you tried the Dimension command?
This is what you're looking for, correct?
I take it you've just jumped right into Inventor without any type of training, formal or informal, am I correct?
If so, as I suggested in your other post, work thru the starting tutorials, they will help you a LOT.
Start with the basics and it'll walk you thru the process of building a part and an assembly as well as how to detail drawings of such. It'll save you a lot of frustration and time as well.
Feel free to reach out to me in pm for help, I'd be happy to assist.
Cheers,
Jim O'Flaherty
Owner - Celtic Design Services, LLC - cdscad.com - An Autodesk Service Partner
We are available for hire. Please DM me or visit our website
Autodesk Inventor Certified Professional * Autodesk Certified Instructor * Autodesk Expert Elite * AU Speaker 2015 through 2022 * AU Speaker Mentor
"Mr. O'Flaherty, never go into small computers. There's no future in them" - Dr. C.S. Choi circa 1984
CCarreiras
in reply to: yefimv
Hi!
It'a a simple task, you don't need a big manual:
Note:
The center marks are facultative, you don't need them to create the dimensions.
Tip:
If you already created the dimensions in the 3D model sketch, you can bring them back to the drawing, find in the image above the tool "Retrieve model annotations" and try it.
CCarreiras
Technology Administrators
