Hi guys,
i'm an amateur in inventor, i use the 2015 version, i need to draw a tubular truss, and i'm having a lot of trouble..
i tried the sweep function but it changes the diameter of the inclinated tubes, i also tried to use the 'insert frame' function too, but it does not have the
sizes i need to work (1/8" and 3/33").
Please, help me!
You can change the size of the pipes manually after building the frame.
Look at the screencast, I used 1/2" pipes for the truss and changed the pipe to 1/8" (I work in mm so for me it's 10.3mm).
Is your profile sketch plane perpendicular to the path?
Can you attach your attempt here?
