Inventor Forum
Planes made by Mid plane between 2 planes
8 REPLIES 8
Message 1 of 9
aprajapati3C
428 Views, 8 Replies
aprajapati3C
In an assembly if a plane is made through "Mid plane between 2 planes", how to identify which planes were used to create it?
I have a model done by someone else. There are few user planes and i have no idea how it was created. I dont want to redefine the planes as it may impact the higher level assemblies.
8 REPLIES 8
Message 2 of 9
CCarreiras
in reply to: aprajapati3C
CCarreiras
Hi!
Click RMB and "Show Inputs"
After this, the input member will highlight
CCarreiras
Hi!
CCarreiras
Message 3 of 9
CCarreiras
CCarreiras
CCarreiras
CCarreiras
Message 4 of 9
aprajapati3C
aprajapati3C
This solution works for part files not for assemblies
Message 5 of 9
blandb
blandb
Good idea for the ideas station lol
Autodesk Certified Professional
Message 6 of 9
aprajapati3C
aprajapati3C
I though of that but wanted to check first is there is a solution which i am not aware of.
Message 7 of 9
WHolzwarth
WHolzwarth
Perhaps I didn't see the issue. But have a look. Planes created in assembly on two different parts, and midplane between them.
Walter Holzwarth
Walter Holzwarth
Message 8 of 9
johnsonshiue
johnsonshiue
Hi! All assembly work geometry is associated with a constraint. For midplane, there should be a Symmetry constraint in the Relationship folder. Select the constraint to see the participating geometry.
Many thanks!
Software Test Engineer
Many thanks!
Message 9 of 9
aprajapati3C
aprajapati3C
Worked. Thanks
Worked. Thanks
