Inventor Forum
Plane Normal to Curve at Point is not aligned
13 REPLIES 13
Message 1 of 14
FS!
795 Views, 13 Replies
Hello, dears,
I'm creating planes normal to curve at a point, but sometimes the plane is not created aligned, or 90º. Why? 😞
Please take a look at the images below. the Work Plane 7 "blue" has this problem.
If I create a sketch it won't be aligned with all the other kinds of stuff.
Thanks a lot!
Fabio S.
13 REPLIES 13
Message 2 of 14
andrewiv
in reply to: FS!
It is because you are created a plane normal to a spline, at least that's what it looks like.  The plane is perpendicular to the spline at the point you selected but it may not be normal to other geometry in your part.  If you want to create a plane aligned with the "Orange" plane then select that plane and the point to create it parallel with the plane and going through the point.
Andrew In’t Veld
Designer / CAD Administrator
Message 3 of 14
FS!
in reply to: andrewiv
Hi andrewiv, thanks for your reply.
All the other planes are normal to spline too.
But, only this is not aligned.
I can not understand it. Everything is aligned, but sometimes any plane is created with no alignment.
Thanks a lot!
Fabio S.
Message 4 of 14
JDMather
in reply to: FS!
I use this functionality on a regular basis.
Attach your *.ipt file here for diagnosis.
Message 5 of 14
FS!
in reply to: JDMather
Hi JDMather,
Is all yours. 🙂
Thanks!
Fabio S.
Message 6 of 14
johnsonshiue
in reply to: FS!
Hi! The part you attached did not have Workplane 7. Please share which plane is not right.
Many thanks!
Software Test Engineer
Message 7 of 14
FS!
in reply to: johnsonshiue
The ipt file attached has the same problem.
Message 8 of 14
JDMather
in reply to: FS!
See Attached.
Message 9 of 14
FS!
Hi, JDMather,
Very nice! You did it!
For now, please explain to me your secret! 😁
Thanks!
FS.
Message 10 of 14
JDMather
in reply to: FS!
Well, I guess I got lucky.  🙄
I finished it and then realized I had done it on the wrong planes compared to your original.
Then I tried to reproduce (twice) relative to the same planes that you used and the User Workplanes did not align.
Pinging @johnsonshiue
I am not sure that is critically important to you.
You could simply right click on the View Cube and set the Top view, but this doesn't change the sketch planes.
I have never worried about this Workplane alignment as I simply Project a reference to use.
Message 11 of 14
FS!
Hello!
We cannot work based on "lock", in my case, ever with applying constraints, the difference is not acceptable.
Take a look, I got a 3.83º difference between the planes.
BTW, Thank you! 😔
FS!
Message 12 of 14
JDMather
in reply to: FS!
I never use Locked except with Sketch Blocks - which is a different topic.
Message 13 of 14
FS!
Hi JD!
Sorry, I did not understand your last reply.
But, I discovered an interesting thing:
If I start a part using the view below, I have no problem with the workplane alignment.
But I will if I start a new part using this view:
For this moment, all right and the work is running.
Thanks a lot!
FS!
Message 14 of 14
johnsonshiue
in reply to: FS!
Hi Folks,
I don't have definite answer to the behavior. But, I think this has something to do with the sketch plane. The Main:WP is tilted against the origin planes (except being perpendicular to XZ). The workplane orientation does not have a persistent bias. I guess it was based on the curve normal and tangent from the 2D sketch with respect to the origin coordinate system. Though it may look odd, I don't think there is a workflow or a solution to make it perfectly aligned to a reference plane.
Many thanks!
