Inventor Forum
Place large number of parts in an assembly
3 REPLIES 3
mjc_design
398 Views, 3 Replies
Hi
I have 50 part files sat in my workspace that i want to drop into a new assembly (grounded at the origin) - does anyone know how i can quickly do this without doing it one at a time?
Thanks in advance
Matt
3 REPLIES 3
mdavis22569
in reply to: mjc_design
Please clarify your post a bit more:
You have 50 part files that are in a .sat?
Mike Davis
mcgyvr
Well you can place multiple parts into an assembly at one time by ctrl+ selecting them..
Or drag/drop from explorer..
Then on the assemble tab there is the "productivity" pane which has a function called "ground and root" component but it only works on one part at a time..
But with 50 pcs it shouldn't take more than a few minutes to insert/ground/root all parts..
If you have to do this whole process multiple times/every day,etc.. then you may be able to create an ilogic rule to perform the ground/root on all parts in an assembly..
mjc_design
in reply to: mcgyvr
Thx mcgyvr.
I'd used make components from a large multi-body part, but forgot to save the new assembly i created. This meant i had a load of part files sat there but no assembly. I had no idead you could place multiple parts as easily as that!
