Pivot Point
Pivot Point
Message 1 of 18
Pivot Point
How can I find the pivot point of a cover assembly ?  I have attached the IDW file.
Replies (17)
Message 2 of 18
mdavis22569
You didn't give the 3d so It's unresolved for however
here is one in my idw
find the view, then the solid for the view, Right Mouse Button ...COG and the point will come up in the IDW view
Mike Davis
Message 3 of 18
Here is the assembly that needs a pivot point.
Message 4 of 18
mcgyvr
@Anonymous An iam file without including all the ipt/sub iam files is useless..
The iam just "links" to those files and does not include them in itself..
So you need to zip up all the ipt files (and any subassembly iam files) and include the main iam file too..
But searching help should get your answer..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
and more..
Message 5 of 18
Sorry about that.  Here is the zip file.
Message 6 of 18
mdavis22569
Did you see how I said to do it ...
PS
O BROWNE PULL.ipt is missing.
I deleted it from the Assembly, here is here the COG/pivot point shows up
Mike
Mike Davis
Message 7 of 18
Centre of gravity does not help in this case .  What I need is a pivot point that will allow the cover to be in position 1 when open and position 2 when closed.  The parts would share a common pivot point location.
Message 8 of 18
I have attached a model of the cover assembly.  It is not exactly what I need but does show the intent.  The pivot point was created by trial and error, not a good way to operate.  The IDW view is what I need to pivot.
Message 9 of 18
CCarreiras
HI!
Still missing "O BROWNE PULL"
You have to attach here all the files: iam, ipt, idw..... all the files... assembly files don't bring the ipt files with it!!!
Make a pack and go!! Check the video about wht you need to do.
CCarreiras
Message 10 of 18
mdavis22569
let me ask you a question ..are you trying to get us to figure out where to put the pivot hole in this for you?
Mike Davis
Message 11 of 18
Curtis_Waguespack
Hi jerr72,
This is one of the few times I like adaptive parts.
What I would do is:
  • create a hole in the stationary part
  • change the dimensions to be driven
  • go a head and make the sketch that controls the position of the hole visible so you can edit it from the assembly.
  • edit the moving part in context of the assembly
  • project the hole from the 1st part to the 2nd making it adaptive
  • cut that hole in part 2
Now you're ready to figure some stuff out.
  • Create an insert constraint between the holes in the two parts
  • Delete other existing constraints if needed
  • Rotate your part and check the location
    • Change your selection filter to Select Sketch Features
    • grab the sketch center of the hole and drag as needed
    • Change your selection filter to Select Part Priority
  • Rinse and repeat, Etc.
When done:
  • turn off adaptively.
  • set sketch dims to be driven in part 1, and give them even dimension values (3.125" vs 3.11984685779")
  • edit part 2 and dimension it with proper dimensions
I hope this helps.
Curtis
Message 12 of 18
Curtis_Waguespack
 not the best video but it should give you some ideas about the steps outlined above.
Message 13 of 18
I was looking to find a formula or procedure to find the pivot point in this assembly.  We do other types of assemblies which require a point also.  I can do this by trial and error, however a better system would be great.
Message 14 of 18
mdavis22569
I do a little trial and error and I do adaptive like Curtis mentioned.
At first it sounded like you were looking from something different now I see what you're looking for.
The problem is no formula is perfect, it changes as the parts change.   A lot of factors can come into play. Some might want it to balance in the pivot, so weight could come into play.
Mike Davis
Message 15 of 18
mcgyvr
I'm fairly sure there is some "geometry math" (gosh its been a while 🙂 ) that will give you the pivot point..
Probably something with circles tangent to the potential contact faces.. and then finding the common intersection point of those circles..
I'm not fully awake yet though and just don't love math the way I used to.
Message 16 of 18
Yes.  Geometry math is the likely solution.  Just where to get the answer is the question.
Message 17 of 18
mdavis22569
time to start 2d sketching ...
Mike Davis
Message 18 of 18
Solved.  I have created the geometric solution to the pivot point question .  I have attached the IDW views .  This procedure works well with all variations of roll covers we make.
