Pipe clips, hangers ? or brackets and fabricated pieces ?
Not an easy subject but for frames, brackets, fabricated pieces you might want to investigate icopy and imates.
If the pipe clips don’t change in length (like a welded base pipe clip, google for pasilac clips) then you can author them as branch fittings and publish them to content center. This will allow you to drop them as any fitting and select orientation and rotation. If you don’t like breaking the route (it creates a new node) then don’t author them as T&P and use imates, or plain constraints.
Keeping them in library as iparts doesn’t work because ipart members are created as derived components and they lose the authoring information. However, publishing iparts to Content Center will generate a copy of the main part with changed parameters so the T&P authoring info is preserved.
For adjustable length parts (like pipe clips with custom length studs) you can use ilogic. Unfortunately there is a limitation here as well. You cannot place ilogic components authored as T&P because Inventor places the main part not the customized part.
For that I open another inventor session and disable T&P addin. Then I generate ilogic components here and place them using “Place Fitting” in the other inventor session where T&P addin is enabled.
Here are more thoughts on this:
http://blog.ads-sol.com/2015/03/inventor-pipe-clips.html
Check the video and download the files at the very end and have a play with them.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
