I watched a this youtube video about how to create a repads we need for many designs. It touched on ilogic and I managed to create a part however when I change any paramaters it comes up with errors with the thicken feature. Can anyone please look this file over and let me know what I am doing wrong? I am at a loss and this could really help us in our designs. I also need this to unfold so we can burn them out.
I am using Inventor 2014.
Thank you in advance.
Todd
Todd
Solved by JDMather. Go to Solution.
Have you installed all Service Packs and Updates on the machine this file was last saved?
Try the attached file and see if it is more robust (I did not take the time to set up the parametrics).
Thanks I will check it out. I just installed a missing update. I will let you know shortly.
Thank you so much. I was able to get this to work. I need to look into exactly how you did that but I appriciate it.
If you can attach your finished part - I would like to add to my book.
