Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Pipe & Tube add in
Pipe & Tube add in
stephenwilco
Pipe & Tube add in
stephenwilco
I have Inventor 2025 Professional. I'm assuming (yeah, I know "assuming") the pipe & tube add in comes with (at least that's what I think I read) BUT, I don't know how to "turn it on". The button does not show up on the frame generator panel.
CGBenner
@stephenwilco
Hello!  You came to the right place.... here is everything you need to know to get started with Tube & Pipe. (it's old but still valid today)
Take a look at the Handout with this class and then we can look at any specific questions you have.  Also, check to make sure that the Add In is loaded so that the T&P Menus show up under Environments when you are in an assembly.
Chris Benner
CGBenner
@stephenwilco Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
