pin icon idw
pin icon idw
bespel
Message 1 of 8
pin icon idw
bespel
I don't remember.
What does it means this pin icon in this context?
And in which waydid it was created?
Thanks!
Replies (7)
Message 2 of 8
christof.gosselin
Hi @bespel,
This icon in my drawings means its grounded, which means you cannot move the object from his given position.
You can fix this with clicking on the part with the right mouse button en deselect the 'Grounded' function.
 Hope this helps 🙂
Message 3 of 8
bespel
Thanks but it doesn't help.
Did you see the icon? I refer to another pin icon
Message 4 of 8
-niels-
@christof.gosselin Views on an idw don't have a "grounded" option, so i don't think that's what's going on here.
I do agree that it's the same icon that is normally used for grounded objects.
@bespel Which version of Inventor?
I never saw that icon before but with a little testing in IV2021 i got a detail view "attached" to some selected geometry (point) and then this icon appeared next to the detail view:
In order to remove that paperclip i can right-click on the originating detail boundary and select "detach" from the popup menu.
Does that work for you?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 5 of 8
bespel
Thanks! But no.
There is no option about attach, ground unground (for what I see).
Message 6 of 8
christof.gosselin
i Think i found something:
Detail views attached to points on parent views
Use the Attach command to associate detail view definitions with the parent view in the drawing environment. If the dimensions or positional relationships of the parent view geometry are altered, the attached view definition remains attached to and moves with the user-specified attachment vertex.
The view definition maintains its relative position to the parent view. A pin symbol appears next to each attached view or symbol in the browser.
This is the website, hope this would help.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
Christof
Message 7 of 8
-niels-
@bespel this is done on the drawing view, not in the browser. does that make a difference in the options provided?
The page @christof.gosselin found is exactly the behavior i found as well, the icon may have changed between versions.
Niels van der Veer
The Netherlands
Message 8 of 8
bespel
Yeah!
It's that!
Thanks @christof.gosselin !!!
(An @-niels- )
