Physical Properties Formatting Output in .IDW
gbradley
gbradley
When Displaying the Physical Properties- Model Mass of an object.
How can I Format the result so that it shows:
7,715.0 rather than
7715.0
How can I adTextFormatting.JPGd the Comma?
johnsonshiue
Hi! Formatting the properties can be tricky. It is because Inventor drawing treats these properties as text. Trying to format a text string in numerical fashion is not straight forward. iLogic rule can help easily.
1) Open the part or the assembly and create a parameter called MASS_Value or something.
2) Set the proper unit.
3) Create a simple rule equate the MASS_Value to the physical mass.
4) Go back to the Parameters table and check Export flag for MASS_Value.
5) Right-click on the Expression cell -> Custom Parameter Format -> select the appropriate option.
6) In the drawing text, select the MASS_Value.
Many thanks!
Software Test Engineer
gbradley
I was following along nicely until I got to:
I could only find Custom Property Format..., but Format: seems to be grayed out.
johnsonshiue
Hi! I was wrong. The workflow I mentioned does not get you the format you were looking for. I should have been more careful before I provided the solution. Sorry for the confusion!
Here is what you need to do with iLogic. Instead of creating a user parameter to capture the mass, you need to create a Text-based custom iProperty. Then literally copy an paste the following code but replace the PropertyName with the actual custom iProperty name.
iProperties.Value("Custom", "PropertyName") = String.Format("{0:#,##0.00}", iProperties.Mass)
It should work. Please let me know if it works for you.
Again, I am sorry for the confusion.
Many thanks!
