PFC channel error?
PFC channel error?
PFC channel error?
BSI 200 x 75 x 20 should be BSI 200 x 75 x 23 shouldn't it? It calculates out in Inventor as 23 kg/m and that is the standard size https://britishsteel.co.uk/media/40513/british-steel-universal-beams-pfc-datasheet.pdf
Xun.Zhang
Hello @50h9j,
You are right, seems the definition of the size is incorrect, but other properties are look good.
Here is a workaround to set the right designation -
https://autode.sk/2AiuUze
Hope it helps!
Xun
