Pegboard
Pegboard
Message 1 of 22
Pegboard
Hello im a seventh grader student making a pegboard with inventor i have instructions about making the pegboard but it is to vague i would like to recieve help so i could build this pegboard beofre friday 8:30 pm plz ryply at the earliest thank you
Replies (21)
Message 2 of 22
Mark.Lancaster
s-nithomas
Welcome to the community..
First you need to tell us what version of Inventor you are using.
Secondly have you started anything?  If so attach the Inventor part file and we can review it.  Show us what you are trying to accomplish.
Next what does your actually instruction say, what are you stuck on?
Where is your instructor?  What does this person have to say if you are telling us the instruction are too vague.  Can you get a clarification from them.
Sorry I'm not trying to be hard on you..
Mark Lancaster
Message 3 of 22
Curtis_W
Hi s-nithomas,
Can you provide some more details on this project?
What version of Inventor are you using?
Have you tried creating a hole using the Hole tool and then  using the Rectangular Pattern tool to create the even spacing?
Do have some files that you have started, that you could attach?
I hope this helps.
Curtis
Message 5 of 22
Curtis_W
Hi s-nithomas,
Unfortunately, that link seems to go to a login specific site that only students or faculty of your school can access. Is there other infomation you can provide?
I hope this helps.
Curtis
Message 6 of 22
Message 7 of 22
I am using Inventor Pro as my inventor and im stuck on making the pegboard, mallet, and the shapes.
Message 8 of 22
JDMather
@Anonymous wrote:
I am using Inventor Pro....
Is that Inventor Professional 2014
or
Inventor Professional 2015
or
Inventor Professional 2016?
This is critically important information as the files are not backwards compatible.
Message 9 of 22
mcgyvr
There is nothing vague about those instructions at all..
They are clear and well defined..
Is there a specific section that is confusing for you?
What have you completed so far?
Have you discussed your "issues" with your teacher?
Message 10 of 22
JDMather
Let's walk through this step-by-step to completion of the assignment.
Start a new part file.
On the glass cube orient to the Top View.
Start a new sketch on the XZ Plane and then right click on the Center Point and select Visibility (you will have to expand the Origin folder first).  Sketch a circle with the center of the circle at the origin.  Post back for next instruction.
Message 11 of 22
I am using inventor pro 2015
Message 12 of 22
I have done what you have told me now what is the next part
Message 13 of 22
JDMather
Dimension the circle Ø1 and then Extrude it 3inches.
Save with the name Round Peg and then attach the complete file here.
I will then give instruction for next part.
Message 14 of 22
I have completed the round peg and square and started the pegboard but im having troubles making the circle and square centered and vertically and horizonantally within the rectangular base.
Message 15 of 22
JDMather
I do not see any files attached here?
Did you read my instruction?  (see post #3, 9 and 13)  They all instruct you to attach your completed work (what you have been able to do - finished or not) here.
Only by looking at your files can you be properly instructed.
Message 16 of 22
Also i am available from 2:40 pacific time to 4:00 or 5:00
Message 17 of 22
mcgyvr
You are a better man than I JD... (or maybe a bigger sucker Smiley Wink )
Message 18 of 22
Message 19 of 22
JDMather
You did not follow my precise instructions on the Round Peg?
Also, is this a school computer or your computer (not up-to-date on Service Packs).
Message 20 of 22
This is a school computer so i can not have the service packs sorry
