PDF to Inventor
PDF to Inventor
PDF to Inventor
 I have a drawing of a part that was sent to me but its missing dimensions. Is there any way I can use inventor, fusion, or autocad to put the pdf in and take dimensions?
JDMather
Place the image into sketch(s).
Dimension the image such that a know feature in the image is correct size.
Start a new sketch and trace over the image.
Attach the *.pdf file here if you can't figure it out.
mcgyvr
The "smartest" way is to request whomever send the drawing to fill in the missing dimensions..
I'm assuming you might be a vendor for them..
I wouldn't want to "risk" making a mistake and then the blame goes on you.
Curtis_Waguespack
Hi Rindos2001,
You can place the PDF into an AutoCAD DWG as a PDF UNDERLAY, and then measure and/or trace over it by snapping to endpoints, etc. If the drawing is scaled you have to scale the PDF Underlay, or scale your traced geometry afterwards.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoC...
Note that I wouldn't typically recommend this for recreating precise parts, etc. but I have used it on occasion to pull missing information from a PDF drawing.
I hope this helps.
Curtis
