This subject was previously brought up on forum but there is no reply from Autodesk regarding misleading information that this bug was fixed.
Obviously it was NOT.
In short:
Problem is that when exporting drawings to PDF objects are placed on layers that are incorrect. Also there are problems with following appearance overrides on assembly level and using proper DVR when exporting to 3D PDF.
This was brought up for AI 2015. In the meantime there was information given by a member of Autodesk Customer Support Jon Dean that this "is fixed in 2017". (2017 was not relised at that time).
This however turned out this is not true. Nothing is fixed.
Since at some point Autodesk informed that "this is fixed" could someone from Autodesk inform us, users experiencing this "fixed behaviour" when can we expect you to keep your word and fix this, but rally fix so it works, rally works.
I have prepared video showing this behaviour.
Also I have prepared data set you can download form my A360 drive at: http://a360.co/2c1kZgA
Cris.
https://simply.engineering
