Pattern hole along irregular shape
I have an irregular tapered lofted shape (see attached) and I am trying to create patterned holes all the way round in four rows (see attached drawing). The shape is hollow and the holes must go through to the inside surface. I apologise if this is simple but I can't work out how to do it! I am new to the forum and would appreciate some guidance.
Kind Regards,
Luke
Cadmanto
Take a look at this thread and see if it helps you with what you are trying to do.
https://forums.autodesk.com/t5/inventor-forum/component-patterning-along-a-curve/td-p/8105108
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
JDMather
While you wait for someone to take a look at your file - I recommend that you install Update 4 for 2019.
johnsonshiue
Hi! This should be fairly straight forward. You need to create multiple parallel workplanes from the top or the bottom. Then create a 3D Sketch > Intersection Curve -> pick the work plane and the Loft body. These curves can be used for patterning. Create one of the hole. Then use Rectangular Pattern command -> select the hole -> select the 3D curve as direction. Please feel free to attach your attempt, if you cannot figure it out.
Many thanks!
Software Test Engineer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
