Pattern features along curve, orientation of feature
I know how to pattern a feature along a curve.  Can I pattern a feature along a curve, but have the orientation of the feature change a specific amount, along the curve?
In other words, I want to pattern a feature along curve A, and the orientation relative to curve B.
Erich
Replies (8)
PaulMunford
It's only possible to have the pattern follow the original direction of a feature or have the pattern run perpendicular to the path. Sorry 😞
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
WHolzwarth
Perhaps like that, who knows? (2016 file)
Walter
Walter Holzwarth
PaulMunford
That's right. There is a 'twist' option in the sweep command. But not in the pattern command.
WHolzwarth
Sure, Paul. It's another way for perhaps getting the desired result.
Smiley Wink Erich is the man, who knows ..
Walter Holzwarth
Please take a look at the attachment.
I'm trying to pattern a rectangle along sketch curve A (I can get this far) and have the orientation relative to sketch curve B (can't figure out this part).  Is that possible?
WHolzwarth
Possible with sketch blocks, if the pattern is not too big. Otherwise there will be some work behind.
2015 file attached
Walter
Walter Holzwarth
I'm not familiar with sketch blocks.  Can you give me a quick run down of the workflow?
Thanks.
WHolzwarth
Read here:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-B79AB016-1E8D-4F4D-A02E-A6C036B42985
They've done it better, than I can.
Walter Holzwarth
