I know how to pattern a feature along a curve. Can I pattern a feature along a curve, but have the orientation of the feature change a specific amount, along the curve?
In other words, I want to pattern a feature along curve A, and the orientation relative to curve B.
Erich
Perhaps like that, who knows? (2016 file)
Walter
Walter Holzwarth
Sure, Paul. It's another way for perhaps getting the desired result.
Erich is the man, who knows ..
Walter Holzwarth
Please take a look at the attachment.
I'm trying to pattern a rectangle along sketch curve A (I can get this far) and have the orientation relative to sketch curve B (can't figure out this part). Is that possible?
Possible with sketch blocks, if the pattern is not too big. Otherwise there will be some work behind.
2015 file attached
Walter
Walter Holzwarth
I'm not familiar with sketch blocks. Can you give me a quick run down of the workflow?
Thanks.
Read here:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-B79AB016-1E8D-4F4D-A02E-A6C036B42985
They've done it better, than I can.
Walter Holzwarth
