Inventor Forum
Pattern along path and extrude cut external curve.
6 REPLIES 6
jcscavuzzo
339 Views, 6 Replies
jcscavuzzo
Good morning !! Having a problem with the position of an extrusion along the path, the deep one does not follow the  arc.
6 REPLIES 6
CCarreiras
in reply to: jcscavuzzo
CCarreiras
HI!
Could you share the file?
CCarreiras
HI!
CCarreiras
jcscavuzzo
in reply to: CCarreiras
jcscavuzzo
Sure.
Sure.
kacper.suchomski
Hi
The array can be easily wrapped along the path, but the array elements will remain rigid. The shaping elements themselves will not be curved on individual path elements. It sews on the principle of caterpillars (segments), not plasticine.
If you really want to get a graphic effect, you can go this route:
  1. Measure the length of the inner loop
  2. Create a flat pattern in an array of cutouts
  3. Make 2 bends to wind the tape and close the loop.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Hi
Kacper Suchomski
kacper.suchomski
Alternatively, you can model it by hand.
Kacper Suchomski
Kacper Suchomski
blandb
blandb
Here is a quick and dirty example, you can play around with it. Not sheet metal, but just utilizing the "bend part" command (2022 version)
Autodesk Certified Professional
in reply to: blandb
