Pattern a bolt pattern along a circular sheet metal body
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Id like to see if someone could give me some tips or best practice for doing this. You can see i am trying to pattern two sets of bolt patterns around a "circular" formed sheet metal body. The spacing isnt really critical nor is the "cant" of the actual bolt holes (they are well oversized). Normally id use sketch blocks, and create a sketch on many of the faces of these lofted flanges. It can be quite time consuming.. When i try to use the circular pattern of feature command, it works.. but it doesnt actually cut the holes all the way through..
Any suggestions, or even a better solution?
