I am trying to use the mold assembly function in Inventor and everything was good until I got to importing a mold base. I have downloaded the libraries unzipped them and have relocated them in to the path that leads to my content center library and when I check my project manager libraries they appear in there, however when I try to access them from my mold assembly they do not appear.
Solved by adam.duenow. Go to Solution.
Hi! I guess the library idcl files need to be migrated. Did you place it in a writable folder? Inventor needs to be able to migrate the idcl file before it can be included.
Many thanks!
Thanks for the reply Josh, I found out what was wrong I was in a company project that would not allow me to add the libraries to the project so I switched to default project and the libraries were accesible in the mold assembly.
