Paste function does not work, if mouse cursor is outside drawing sheet boundaries. Why is that? Bug?
If you have mouse cursor inside the drawing sheet boundaries and copy a view (or anything else) and then exit the boundaries, you cannot paste until you go inside boundaries again.
This also causes errors with iLogic rules (if you use copy / paste commands), if mouse is outside the boundaries. I spend several house to figure out why code does not work (LoL).
Solved by Olena.Rubin. Go to Solution.
Not sure why but I noticed it years ago so the behaviour is not new..
Inventor 2021, 2022, and 2023 have resolved this issue.
I recommend updating to a later version.
Check the screencast with reproducing this command in 4 versions below:
"Paste" command not working in Inventor 2020, when cursor is outside of the sheet
Do you find this information helpful? "LIKE" this answer! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цьому повідомленню!
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button. | На ваше запитання відповіли? Натисніть кнопку 'ПРИЙНЯТИ РІШЕННЯ'.
Olena Rubin
Technical Support Specialist Autodesk | Фахівець Технічної Підтримки Autodesk
