- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Inventor 2012
I have a large assembly (20,000+ parts) which consists of many layers of assemblies and fabricated, machined and purchased parts. When I generate the top level Parts Only BOM I expect to end up with the list of items I need to purchase in order to assemble the final product. However, the list that is generated includes the "purchased" parts that are part of "purchased" assemblies. This is consistent with the knowledge article below, but can anyone help me understand why it works this way, and how to get a final list of the parts and assemblies I need to actually purchase.
See paragraph 3 of "Parts Only View"
As a simple example, I have an air filter assembly which is purchased from a vendor. It contains a canister (BOM property Normal), filter (BOM Purchased), barbed fitting (BOM Purchased), bracket (BOM Normal), and several pieces of Content Center hardware (BOM Purchased). My final Parts Only BOM contains:
Air Filter Assembly Qty=1
Filter Qty=1
Barbed Fitting Qty=1
Hex Screw Qty=4 more than I need
Washer Qty=4 more than I need
Nut Qty=4 more than I need
But since I already buy the assembly, I do not need to purchase the filter, barbed fitting, or the hardware separately. I could change the BOM property of the filter and barbed fitting to Normal, but that doesn't make logical sense, and the hardware is in the Content Center, so I cannot modify the property.
If this were just one small assembly, I could go through each line manually and determine what was not needed, but with such a large assembly it becomes nearly impossible to try to decrement the top level number of pieces of hardware that have been promoted, vs the quantity that needs to be purchased.
Is there something I'm missing? Is the Parts Only BOM not the correct method of obtaining my final list of items to go purchase?
Dan
