Hello there,
I encounter a problem whilst making a dwg file of my assembly. This overall assembly includes a motor assembly which I obtained from a supplier as a step file. When I want to make a dwg of the assembly the housing part of the motor is not showing. I have tried several things to solve this, checked the motor model on transparency etc. I hope someone can help me with this problem.
Solved by mcgyvr. Go to Solution.
Edit the drawing base view.. Go to "Recovery Options" tab and check the box for "Include Surface Bodies"
