Hello!
I have an assembly made by two subassemblies. In the part list of whole assembly are shown just subbassemblies. I need a list of all parts, but I do not know how to make it. Help!
Take a look at the parent assembly's BOM Editor. Change the settings on the Structured tab to All Levels.
Once that is done, you should be able to edit the Part List on the drawing and expand out all the sub-assemblies.
https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-6C58657F-C902-433F-9AA6-22A2ACA09F16
Steve Walton
Thanks, but it doesn't work; I've tried "parts only (legacy) and still is not good.
I got same name for different parts:
Do you know why this happens?
Hi! I believe the "Row Merge" option in the assembly BOM was turned off. Open the assembly and go to BOM table -> find the Row Merge setting in the middle at the top -> check "Enable row merging based on part number."
Many thanks!
