Parts list not updating Item quantities from Frame Generated Parts - BOM Does
RockyBrown4134
Message 1 of 8
RockyBrown4134
Has anyone run into the issue where the parts list will not update correctly with and assembly Bill Of Materia? Especally parts generated from Frame Generator? I have a drawing with 32 sheets, and on sheet 27 and 28 there are parts generated with frame generator. Some quantites of like parts will not update correctly. See saatched.bom1.jpgbom2.jpg
Any suggestions?
PS: on other sheets I have other frame generated parts and the seem to work ok.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
Replies (7)
Message 2 of 8
mdavis22569
If you open the Parts list ...is the text in Blue, like it's been over written?
Mike Davis
Message 3 of 8
RockyBrown4134
no overrides in area of question (Pipe, 1 1/2" SCH 40). I put overrides in on hardware items. Doesn't make a differance.
Rocky Brown
Message 4 of 8
mdavis22569
Can you share it ?
defered updated I'm assuming isn't on ...
BOM's are matching for Parts List and Views?
Grabbing without being able to see it ...
Mike Davis
Message 5 of 8
RockyBrown4134
Let me see what I can do. Large file, so let met try to break it down.
Rocky Brown
Message 6 of 8
RockyBrown4134
File is 8 mb. Can you send me an email so I can send a Dropbox invite?
Rocky Brown
Message 7 of 8
Is there a group filtering option turned on, or is it combining lengths?
Message 8 of 8
RockyBrown4134
Parts List editor will not let me select the group setting.
Rocky Brown
