Hi All, update from previous - problem persists following re-install. Clean uninstall of inventor 21 & 22, files & new install inventor 2022.
Default project set to Read & Wight
Using default templates opened standard.idw and modified Label text to Justify Left in the styles editor.
Go to Manage Styles, Save.
'Migrate Styles to current release' popup(see attached), why not current if new install? pressed OK. Close file.
Open New Part & get Styles Conflict box popup, Lighting - IBL Default (see attached), click ok - go to Styles, lighting & All default IBL Environment tabs 'Image Based Lighting section' have disappeared. Now just showing Lighting & shadows tabs only (see attached) on all default styles.
Go back & open the Part Template directly and the Default_IBL lighting has the environment tab, but all other defaults the tab is missing?
Checked C:\Users\Public\Documents\Autodesk\Inventor 2022\Environments & all files are present. check file path in project and the same.
Its Migrate to current release that seems to generate the issue, I made the modification the new default template install files from 2022, could there be a legacy Styles Manager that the install is picking up on? Otherwise why would it want to migrate to current? I did delete all files as listed by Autodesk & in the system registry to hopefully obtain a full clean install???
Had to set up some lights in the default IBL and save for now, at least Part isn't Black for now, just no environments
Hope solution comes soon
