Part won't move with one constraint
BCrosby
Message 1 of 81
BCrosby
I am placing components in an assembly model and constraining them. After placing one constraint on a part, it is locked down and will not drag. Any thoughts?
  • The red cross is not on
  • No grounded parts
  • No sick contraints
Bruce M. Crosby
Broomfield
Engineering Department
GIGABYTE Z490 Vision D (Intel LGA1200/Z490/ATX/3xM.2/Dual Thunderbolt 3/SATA 6Gb/s/USB 3.2 Gen 2/Intel WiFi 6/Direct 12 Phase Digital Power/Intel 2.5G LAN/Motherboard)
Intel Core i7-10700K
Samsung (MZ-V7E1T0BW) 970 EVO SSD 1TB - M.2 NVMePNY Quadro P5000 VCQP5000-PB 16GB
Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 128GB 32GBx4
Dell Ultrasharp U4919DW Curved 32:9 49” Display
Windows 10 Professional 64 Bit
CAT 7 Ethernet
HP Designjet T3500
3D Connexion SpaceMouse Enterprise
3D Connexion CadMouse
Autodesk Vault Basic 2020
Autodesk Inventor Professional 2020
Autodesk AutoCAD Mechanical 2020
Replies (80)
Message 2 of 81
Cadmanto
My thoughts are I have experience this.  Usually if I shut down Inventor and come back in it fixes it.  Otherwise there is still this command if you need it.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 81
johnsonshiue
Hi! This usually means there are pre-existing failed constraints. Inventor fails to find a good solution in such state. Could you fix up the pre-existing failures or simply delete the failed constraints? After that, does it work now?
Many thanks!
Software Test Engineer
Message 4 of 81
BCrosby
Inventor doesn't give me any indication that there is a problem. I only know that when I place a component and one constraint, I can no longer move it. My experience tells me there has to be another issue somewhere but I can't find it. The red cross is not on indicating an issue.
Bruce M. Crosby
Broomfield
CAT 7 Ethernet
HP Designjet T3500
Message 5 of 81
johnsonshiue
Hi Bruce,
If possible, please share an example here or send it to me directly ([email protected]). I would like to understand the behavior better.
Many thanks!
Message 6 of 81
3D4Play
I have exactly this same issue. Applying a single constraint for one DOF to a component causes behavior as though the component has been grounded, complete with the "no dragging allowed" icon when I try to drag it after placing the constraint. I just submitted a support case for it, along with a dataset -->CaseNo:14239457. I've marked it critical because it is negatively impacting productivity. I will also email it directly to you Johnson, as it is only about 12 Mb
Message 7 of 81
johnsonshiue
Hi! I will take a look and understand the behavior better and get back to you.
Many thanks!
Message 8 of 81
johnsonshiue
Hi! I took a look at files you shared with me. This is a case of lacking grounded component. All of the first-level components are free to moved (some are constrained). But, none of them is grounded. I would ground at least one of the components to reduce degrees of freedom. You will find after doing so, the constraint will work.
Many thanks!
Message 9 of 81
3D4Play
I did ground a component that was already fully constrained. It had not effect on this issue. I've followed up with you via email with screenshots.
Message 10 of 81
I've got the same problem. after one contraint the component will not move anymore. I also have at least one component grounded how did you solve this?
Message 11 of 81
MoshiurRashid
Constrains and joints are nothing but making the Degree of Freedom of a part more controlled. You might have constrained your part as there is no degree of freedom left.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 12 of 81
JDMather
@Anonymous wrote:
I've got the same problem. after one contraint the component will not move anymore. .
Does Manage>Rebuild All return any errors?
Are there any issues indicated in your Relationships folder?
Attach your assembly here and end all doubt.
Message 13 of 81
johnsonshiue
Hi! Please share an example exhibiting the behavior. Without the files, there is not much I can do.
Many thanks!
Message 14 of 81
I'm having the same difficulty. I know it's almost always something simple but i'm blank. I've looked at everything I know. Has there been any resolution to this issue?
Message 15 of 81
johnsonshiue
Hi Phillip,
The behavior is certainly wrong. But, without seeing the files, I can only guess. Try the followings and see if they help.
1) Ground a major component.
2) Activate LOD:Master and go to Manage -> Rebuild All.
3) Delete or suppress or fix up all the sick constraints.
Does it work better now?
Many thanks!
Message 16 of 81
mp
Hello. I had the exact same problem and the solution was to delete a component pattern from the assembly, apparently, there was something wrong with it, but I had no errors 🤔
Message 17 of 81
3D4Play
I have same and similar complaints going back to 2018. Fully constrained components should be in effect the same as a grounded component. Patterned components built from either a grounded, or a fully constrained, base component should cause no issue when constrained to. Etc, etc.
That said, I've learned to double- and triple-check the source of constraints to make sure you are constraining to a(nother) fully constrained element. Another way to think about it is to consider the contraint chain - what is being constrained to what, and how far backwards do you have to go in the constraint chain to get to something else fully constrained.
I work in patterned assemblies all of the time. I try to only constrain to fully constrained elements, so the constraint chain is strong. A patterned component is not really fully constrained - though it seems like it should be.
If the constraint is intended to be "driven" by a patterned component, then make sure the patterned component is driving the pattern, not part of the patterned components - otherwise that patterned component will need to be individually "overconstrained", or grounded.
I have also had to delete patterns, in the pathway to "redo".
I don't know if it will help you here, but it has certainly been a long and painful lesson I've learned over the years.
Just my .02
Message 18 of 81
johnsonshiue
Hi! There are several reasons a component may appear locked up. If possible, please share the files here. Forum experts and I can take a look to understand it better. Did you try Manage -> Rebuild All?
Many thanks!
Message 19 of 81
3D4Play
Shazam! This exact thing just happened to me. I closed then reopened Inventor, nope. I rebuilt all. Nope. I deleted constraints. Nope. I added a constraint and the component went right where I wanted it....but it would NOT drag there. I did a free move, dragged the component off-position, exited the move command, then flexed the component to watch it pop back into its "locked" position. After playing with it for a few minutes, I discovered that the component would let me drag it once, after it popped back into position, as long as I kept the mouse button depressed. It is replicatible, and I do have a video. Johnson....your turn! Send me an upload link and I'll let you work your magic.
Message 20 of 81
3D4Play
@johnsonshiue The PNG dataset ended up being smaller than anticipated, so I emailed it to you.
