PART SHOWING AS REFERENCE IN DRAWING BUT NEED TO BE ACTUAL PART
michael.crawforthNGA5X
Message 1 of 34
I am creating a computer server cabinet and am having an issue when in the model and drawings.
In both the assembly model of the cabinet frame and all attached components are showing as reference parts. I have been into the BOM to change this but the field to change this is greyed out. It is utterly frustrating as all the parts within the cabinet have to be ballooned in the drawing but i cannot ballon them and they don't show in the drawing BOM.
Can anyone shed any light on this.
Unfortunately i cannot post images or screen grabs due to the sensitivity of the information within the drawings.
Many thanks in advance
Michael
Replies (33)
Message 2 of 34
Cadmanto
When you say you have been in the BOM to try and change this reference field, are you talking about in the drawing?  Or in the assembly model?  Or, have you tried both with no success.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 34
I have done it in both the model and drawing with no success
Message 4 of 34
mcgyvr
Is this example bom structure similar to yours?
TopLevelAssy.iam
 -cabinetframe.iam (marked as reference)
 --part1.ipt(marked as reference)
 --part2.ipt(marked as reference)
 -otherassys.iam
 -otherparts.ipt
If so have you done the following
#1-Opened cabinetframe.iam and gone to tools..document settings..Bill of Materials tab and changed (or ensured that the bom structure is set to "Normal" (repeat for any/all files that are marked as reference)
#2-Opened TopLevelAssy.iam and right clicked on cabinetframe.iam and gone to "Bom Structure" flyout and set it to "Default(normal)"
Message 5 of 34
Cadmanto
So, you have tried what I show below?
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 6 of 34
I don't remember doing either.
How can i correct this as it is meaning vital parts of the assemblies are not being ballooned or added to the drawing BOM table.
Message 7 of 34
Here is what i have done and what is seen, i have redacted all the information that i cannot disclose
Message 8 of 34
mcgyvr
Assuming you were responding to me..  please answer the question about if the example bom structure is similar to your situation and then perform both steps I posted above and let us know if that solved the issue.
Let me know if you have any problems and please include specific details.
We can help but since you can't share your models we need you to be very specific/detail oriented in your responses.
Message 9 of 34
mcgyvr
Based on the image you just posted nothing is marked as a reference part.
Do you mean that some items in your drawing and showing with "hidden lines" or something else?
What is your definition of a part "showing as reference"
If those are showing as hidden lines is it because those parts are behind (or inside) something else like the cabinet door?
Message 10 of 34
No they are showing as referenced parts, that is why i am so baffled as to what is wrong with the drawings.
Message 11 of 34
When i goto select the parts in a drawing there are unselectable and they also don't who it the BOM table in the drawing
Message 12 of 34
Message 13 of 34
Cadmanto
I don't see a response to what I posted above.  I never mentioned anything in my above screen shot regarding the drawing.  That was in an assembly  RCing on the part.
I agree with @mcgyvr  you need to be specific with your answers and make sure you are NOT responding to yourself as either one of us are just guessing as to who you are responding to.
Remember we are not sitting at your work station being able to try different things.  We are flying a tad bit blind here and relying on what you are telling us.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 14 of 34
mcgyvr
What is your drawing selection filter set to?
Can you edit the parts list in the drawing and show us that parts list dialog box? (black out what you need to)..
Message 15 of 34
Drawing selection filter ?
Message 16 of 34
mcgyvr
https://blogs.rand.com/manufacturing/2014/03/get-picky-in-inventor.html
Message 17 of 34
thomas.fitzgerald
Typically, if you cannot change the BOM Status of a component in the Assembly BOM, then it means the file is Read Only.  Make sure your files are write capable.
Thomas Fitzgerald
Principal Implementation Consultant
Message 18 of 34
johnsonshiue
Hi Michael,
A part can be set as Reference in two places.
1) In Document Settings, BOM tab, you can set the part to be Reference. This will be the default BOM structure property for the given part when consumed in an assembly. The change here requires you to save the file. Also, if you make the BOM structure change within BOM dialog, it applies to the document.
2) Another place is at instance level. Open the immediate assembly having the part and right-click on it -> BOM Structure -> Reference or Default. This change is at the instance level. Default means the Document Setting (#1) will be honored.
The behavior you described sounds like the part is either a library part or a CC part or a readonly part like Thomas mentioned here. Please feel free to send the files (zipped) to me directly ([email protected]). I can take a quick look to understand the issue better.
Many thanks!
Software Test Engineer
Message 19 of 34
Thanks for all the help but nothing is working at the moment
Message 20 of 34
IgorMir
Well, could you please post a part and an assembly which exhibits such a behavior?
Igor.
Web: www.meqc.com.au
