Part of assembly not showing up in drawing
aberrey
aberrey
I have a purchased part with a file that was provided from the manufacturer. It is originally a Solidworks file. When I bring it in, it looks fine in the model, but when I open a drawing with it most of the part isn't showing up. What could be causing it and how do I fix it?
CGBenner
@aberrey
It looks like the part is mostly surface bodies.  In your drawing, right click on the part in the browser and try "Include all Surfaces".  It's been a while, but I think that may make them visible in the drawing.  You may have to do that for each view.
Chris Benner
blandb
In the drawing, edit the view > Recovery Options Tab > Check Include Surface bodies.
Autodesk Certified Professional
aberrey
This worked! Weird spot to have that option though
