Part No 6 - Wing Nut is not given in the assignment. Is there any way to overcome this issue?
Solved by JDMather. Go to Solution.
I usually go to McMaster Carr for that type of one-off hardware.
http://www.mcmaster.com/#standard-wing-nuts/=13a66ur
I might also check http://www.cbliss.com/inventor/Parts/Fasteners/index.htm for ipart models.
Steve Walton
@Anonymous
If that given part/item is missing from the assignment what does your instructor/mentor say to do? Are you suppose to learn how to model it? You only show a sectioned/balloon callout view.. What are you learning in this assignment? You come here looking for answers but give us no clue what this assignment is about. Are you suppose to show the wing nut? Is it need to complete the assignment?
Mark Lancaster
& Autodesk Services MarketPlace Provider
uhmmm,
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-97683B08-1AEC-4371-9199-F14C9A932A6C
