Part Edges are too Bold
KaynePellegrino
Message 1 of 12
KaynePellegrino
On my work PC the edges of the part are thin and clean. But on my home pc the edges seem very bold in comparison. Unfortunately I don't have a picture of the parts from my  work pc. Is there a way to adjust edge boldness of parts in Inventor 2025?
Replies (11)
Message 2 of 12
kacper.suchomski
Hi
Line width can be controlled in the drawing environment, but not in the part file.
I wonder if the difference might be due to monitor resolution.
Kacper Suchomski
Message 3 of 12
KaynePellegrino
I currently am at 4K resolution with 120 hz refresh rate, so I would hope that's not the issue. But even when I lowered the resolution, it didn't change the edge boldness. So I'm not sure
Message 4 of 12
kacper.suchomski
Is the display style set to "Technical Illustration"?
Kacper Suchomski
Message 5 of 12
pcrawley
I noticed something similar in 2025.  4k monitor at work - not 4k at home - and I have a laptop - so I knew what I was seeing was monitor-related.  The highlight edges are noticeably thicker when you select/highlight something on a non-4k monitor.  But I don't think that's quite what you are asking.
On the Work computer, what is the setting Tools > Application Options > Display:
- Use Document Settings or
- Use Application Settings?
It might be that the two computers have different settings.  At home, you may have "Application Settings" so you are seeing the models using the "Display Settings" specific to the installation of Inventor.  At work you may have "Document Settings" so it uses whatever was last used there.
Things like "Contrast with Part" and "Contrast with Background" can make a huge difference.
But other than that, I can't think of any mechanism for making the lines bolder.
Peter
Message 6 of 12
KaynePellegrino
No, I only use Shaded with edges on high quality
Here's my work computer compared to home computer. Just got to work a little bit ago
The lines of the home computer are noticeably thicker
Message 7 of 12
kacper.suchomski
I also see 2 different lighting styles.
Did you try Peter's suggestion about setting the line color?
Kacper Suchomski
Message 8 of 12
KaynePellegrino
Currently on my work computer
I have contrast with part and they appear thin. When switching to "one color" they do seem to appear bolder
When I was home switching things around, I'm fairly certain I changed between all three, but it's possible I never "applied' the setting because I don't remember seeing a difference.
When I go home today I'll try it again and see if there's a difference
I also noticed that the when the Hardware Ribbon (application settings) is set to Quality mode, the edges appear bolder, as opposed to when it's in Performance mode. So maybe I have too may settings trying to be "Quality" at home
Message 9 of 12
KaynePellegrino
Just did, it helped, but won't 100% know i it worked at home until I go there. So we shall see if that solves my home pc issues. I hope
Message 10 of 12
pcrawley
As Kacper says, you also had two different lighting styles (or rather - shadow settings).
It looks like ambient shadows at work, and no shadows at home.
It might be a combination of shadows and the Lighting Style, Visual Style, and Hardware setting in Application Options.  So many choices!
Peter
Message 11 of 12
KaynePellegrino
So turns out it was the settings you guys suggested. Using the "Contrast with Background" and making sure it's in performance mode changes the edge boldness to what I wanted. But it also is from my Home Monitor having 1/2 the Resolution as my Work Monitor.
Work Monitor: 3840 x 2160
Home Monitor 1: 2560 x 1440
Home Monitor 2: 3840 x  2160
Turns out my main monitor had the worse resolution. When on Monitor 1 it looks perfect, just like at work.
Now I need a new monitor 😂
Message 12 of 12
pcrawley
Great - glad it is solved.  Don't forget to mark the solution so others can find it next time someone hits the same problem.  For your new monitor... I can recommend NOT getting a curved screen - it has taken my brain months to learn that all the straight lines are actually straight - not curved due to the screen distortion.
Peter
