Importing Parasolid files
Open and change models created in Parasolid (up to version 20.0). Autodesk Inventor translates assembly and part files, solids, multi-solids, surfaces, and more. After the import operation is complete, you have a base feature or features which match the geometry and topology of the original file. Use Autodesk Inventor commands to adjust the base features and add new features to the feature tree.
These types of Parasolid files can be imported:
*.x_t (text)
*.x_b (binary)I hope this helps,
After changing the file, you can continue to open it in Autodesk Inventor.
*.x_t (text)
