I created a UCS referencing a User Parameter whose value is an angular dimension. When I change the parameter's value, the UCS doesn't change with it. Is this workflow not possible? Seems like every other part feature in Inventor is parametric except this?
Solved by SometimesInventorMakesMeAngry. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Hi! It should work. The part-level UCS has two types (parametric and associative). The former is to click in the Model Space without selecting a vertex. The 6 parameters (3 distance parameters and 3 angular parameters) will be created on the Parameters table.
The latter requires three vertices (first = origin, second = X axis direction, and third = Y axis direction).
Please share the file here. I would like to understand why it does not work.
Many thanks!
Hi, Johnson. See the attached file here. I place a UCS at the Center Point. Then, I create a User Parameter called "angle" with a value of "135 deg". Then I redefine the UCS, click on the UCS's x axis and enter a rotation of "angle". Once I finish redefining, I edit the value of "angle". Nothing happens.
From what you said, it seems like the correct workflow is to try to find the appropriate model parameter for the rotation I need and edit that instead (or assign the value of "d3" to be "angle", I guess).
Part is in Inventor 2019.
Hi! After you enter the X angular offset or any other offset, you will need to right-click in the graphics windows -> Finish. Otherwise, the change will be reverted as is not committed.
Many thanks!
I understand. I did this. However, upon finish (and the angle being updated to 135 deg), if I now change the value of "angle" to "110 deg" in the Parameters table, the UCS does not update to reflect the new value.
Hi! I see the issue now. Indeed, the angular offsets cannot be driven by parameters. When you redefine the UCS, the rotation is done in a sequential manner (one axis at a time). When you change one angular offset, the other two may rotate (triad).
This looks like a limitation in the way Inventor UCS works.
Many thanks!
