Parameters of model not calculating correctly ??
I am trying to create a parametric spherical tile.
I know the length & widths of my tiles, but to create the revolved sketch of the arc I wanted to use parameters  to calculate the revolved angle.
So I can input the width as a length of arc, say 120mm and it will revolve the sketch to the correct angle.
However when trying to transpose the formula for length of arc, L= 2*pi*Radius * (angle / 360)
to
angle = (Length of arc / (2*pi*Radius)) * 360
It is not calculating even close to the 4.2° I am expecting.
plus the formula is coming out red and it is confusing the units...
I have previously done calculations this way in 2017 without problems.
So I broke it down in stages:
A1= PI * Rad_Sphere
A2 = A1 * 2
A3 = Width / A2
Width here being the width of tile, or length of arc = 120mm
and it is coming out as 0.119366
where as this should be 0.0119 - so it is out by a factor of 10
What is going on here ?
Have I missed some simple tick box/ check ?
Thanks, I would paste a snip but it won't let me...
I think I have been able to attach.
Thanks, Neil
Sergio.D.Suárez
Hi, make sure to place the correct units, see the image that I attached. Observe the correctly placed angular units and the parentheses for the equation. The reddish color would indicate in your case a unit problem
I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
I thought I had that covered.  when I set to degrees it wouldn't accept.
I will try again and check the brackets.
Neil
johnsonshiue
Hi Neil,
A3 is a length parameter with a unit of mm. But, the equation actually returns a unitless value (Width/A2). I think you can add *1mm to the equation to convert the unitless value to a length value again.
Many thanks!
Software Test Engineer
NileshV.Khairnar
i faced same issue earlier then i found this unit issue
Thanks, definitely a unit issue, thanks
