Parameters not showing up in the parameter dialog box?
diego.veloso.98
diego.veloso.98
Hello, I'm having an issue for some time now, and It really boders me. The problem is that I have some parameters set up in my model, but those wont show up in the parameters dialog box. When I go check my feature, like my extrusion where I created the parameters, It still with the name I gave It, but this wont show when I open the parameters dialog box again. Whats going on ?
Thanks in advance
mcgyvr
please post the ipt file.
johnsonshiue
Hi! Something seems off to me. The parameter for Distance A isn't listed on Parameters table. What is the Extrusion type? Is it bi-directional or something else? If you switch it to bi-directional, does the parameter show up?
Many thanks!
Software Test Engineer
diego.veloso.98
Hello, the ipt file is attached. When I was modelling my girder the parameters would show up in the dialog box, but after closing and opening again, It doesnt anymore.
johnsonshiue
Hi Diego,
Many thanks for sharing the part! Something seems wrong to me. As I mentioned, some of the model parameters should be there. Our internal debug tool does report the existence of the parameters. But, somehow they are invisible. I cannot explain the behavior. I need to work with the project team to understand it better.
In the meantime, are you aware of the steps to reproduce the behavior from scratch?
Thanks again!
MjDeck
Hi Diego,
 Are you using the Infrastructure Modeler plugin ? It looks like that will make some parameters invisible when you export a part.
 I can send you an iLogic rule that will make them visible again. But first I will try to find out if making them visible might cause any problems for the Infrastructure Modeler.
Mike Deck
Software Developer
Autodesk, Inc.
