Hi all.
For example, I have a part file of an I-beam, and drawn with the length of the I-beam made into a named parameter and exported so it appears in the custom properties tab. From here, the "Description" box in the iproperties is modified to call up the parameter using
=<Length>m I Beam
It works fine and the length appears properly. However, when the part is inserted into a drawing, the model iproperties Description field in the part gets copied to the drawing iproperties Description field, but because the custom "Length" property is not copied over as well, the Drawing ends up with a blank in the Description where the length should be.
Is this a known issue and is there a work around for this? I'm using Inventor 2022.
Thanks.
