Loft Tool
Loft Tool
josh_weatherill
Message 1 of 10
Loft Tool
josh_weatherill
Hi all,
I'm looking for some advice to get the loft tool working correctly. I am trying to model a rectangular pipe that twists 90 degrees whilst following a 3D curved centre line. I am relatively new to Inventor so I'm not quite sure how to constrain my sketches correctly to achieve my goal.
Below is my current attempt at using the loft tool with centreline and it returns the error "The attempted Centreline Loft has a centreline that is not smooth. Try modifying the centreline so that it is smooth.". I'm unsure of what the issue is and how to solve it.
Thank you for reading, any tips would be much appreciated.
Josh
Replies (9)
Message 2 of 10
blandb
Can you share your part?
Autodesk Certified Professional
Message 3 of 10
Frederick_Law
Line segments should be tangent to next one.
You might need a few "rails" to control the rotation.
Message 4 of 10
josh_weatherill
I've attached the part.
I believe that it is conncected to the centreline.
Message 5 of 10
blandb
Here is a 2022 test part
Message 6 of 10
josh_weatherill
Thanks for that!
Would there be any way to retain the pipe cross-section throughout the tranistion?
Message 7 of 10
blandb
You have a lot of "undefined" sketch info. That could be causing some issues.
Message 8 of 10
blandb
As in making it appear to be a Rectangular tube that is bent and twisted? If that is what you mean, you could do a Shell of your desired wall thickness, and then choose to remove end faces.
Message 9 of 10
josh_weatherill
I am wanting the solid to remain the sam shape through out the centreline. I have just tried to use the sweep tool instead to achieve the desired shape and have gotten close. The resultant shape will not allow any degree of twist to be applied so perhaps this method will not work. I'm aiming to get the end of the shape to rotate so it lines up with the sketch.
It is still a good demonstration of the sort of shpe I am after, see below.
Message 10 of 10
johnsonshiue
Hi! This can be done using Loft + Sweep. The Loft creates a good twisted surface. Then use it as a guide to sweep.
Many thanks!
Software Test Engineer
