Thank you very much for the prompt reply JD.
I hope you can open my ipt file. Its a master geometry file of sketches for parts for an assembly.
I'll be be changing certain parameters such as OD of sleeve from 36" to say 22 - 24 inches depending on the project. I would like to automatically change the distance from the axis of the tube (sleeve) to the back face of the stiffener/centraliser plates, because the plate has a square face landing on the curved surface of the inside of the sleeve (round tube) I need to bring the face back slightly so only the edges of the plate touch the sleeve's inside face.
I'm using the adjacent side of a triangle (inside radius of sleeve (tube) and half the plate thickness) to establish the slight difference in distance required to bring the plate in towards the axis of the tube slightly.
I will appreciate greatly any help you can give me as once I've got my head around this I can make other adaptations to control other geometry.
If you require further clarification I'm at cfairfowl@hotmail.com
Thanks again,
Kindest regards
Chris.
