Parallel sketch lines are not parallel
artur.pelicho
Message 1 of 14
artur.pelicho
Hi, first of all, I'm sorry if I make any gross english mistake.
Also this is my first post, so feel free to  to tell me if this is not the correct place to post this.
I'm a new Inventor 2018 user (came from SW background) and I'm having a weird issue (many, but this one is anoying).
When I use the parallel constraint, the lines look parallel, but if I try to give a spacing distance between them I get an angle distance instead of 179.99º
This error is very easily resolved by not using the constraints and setting a 180º angle instead, but I can't but feel this is some kind of user error and really wish to start on good bases.
Picture anexed.
Thank you very much,
Artur
Replies (13)
Message 2 of 14
Cadmanto
Artur,
You English is fine and welcome to this forum.
Based on looking at your image, the lines are parallel to each other, but not to what ever you are dimensioning too.  Make the one line parallel to that edge/line and you will get the 180°.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 14
TheCADWhisperer
Attach your *.ipt file here.
There is no difference between SolidWorks and Inventor as far as sketch relations and dimensions are concerned.
Message 4 of 14
johnsonshiue
Hi! There should be a logical reason in this case. I suspect the geometry may not be parallel. To prove that, we need to see the part file. Please attach it here or share a simplified example.
Many thanks!
Software Test Engineer
Message 5 of 14
artur.pelicho
Hi, and thank you for your answers
@Cadmanto,
The 179.99º showing is between those two lines,.. that are supposed to have a parallel constraint.
@Cadmanto@johnsonshiueI'm attaching the ipt to this post.
Message 6 of 14
I_Forge_KC
You've actually selected the EQUAL constraint instead of the parallel.
They look similar...
K. Cornett
Generative Design Consultant / Trainer
Message 7 of 14
TheCADWhisperer
Message 8 of 14
ToddPig
I have seen this many times, and when it happens I dimension the endpoints of the lines after using the parallel constraint. (rather than selecting the lines themselves)  Sometimes this causes problems later on, but at least you can keep moving.
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
Message 9 of 14
ToddPig
@TheCADWhisperer, I think you have a typo there. The "no" should "a huge".
Inventor 2018
iParts = iHeadache
Message 10 of 14
artur.pelicho
Indeed ! I feel dumb ! I knew it should be something quiet obvious.
Thank you very much for your help !
Message 11 of 14
TheCADWhisperer
True, there are a lot of tools that SolidWorks falls far behind on.
I can prove it.
I do every day.
Message 12 of 14
ToddPig
I would love to see this.  I use both programs daily, and feel like Inventor is very far behind Solidworks.  It would be great to be efficient in both programs.
A few areas that I feel are lacking in Inventor, are...
1. Designing within the context of an assembly
     (In Solidworks, you can always edit the part in the assembly, in Inventor you have to make sure there are no assembly files open, and the part can also not be an ipart)
2. Apply GD&T to a drawing
3. Draft Ananlysis
    (In Solidworks, you set a draft angle, and it's very easy to see surfaces that have less draft than this, you can also hover over any surface and the angle is shown.  The Inventor draft analysis is so cumbersome, I export the part to SW)
Inventor 2018
iParts = iHeadache
Message 13 of 14
TheCADWhisperer
I have used both daily for 16 years.
I think that I am efficient in both programs.
Message 14 of 14
ToddPig
@TheCADWhisperer I want to believe you, but my belief alone doesn't make me more efficient.  The reason for visiting this forum is to become more efficient in Inventor.  You mentioned you could prove that Solidworks is lacking when compared to Inventor.  Can you please share this info?  Or, since this is an Inventor forum, can you perhaps share the features you think Inventor beats Solidworks on?  If any of these things coincide with my previous list, it would be great.
Inventor 2018
iParts = iHeadache
