Has anyone else noticed that when attempting to create a feature using the new pane features that you can no longer click a sketch dimension when the Dimension field is highlighted and have it reference that dimension?
It seems like this is moving away from helping people use robust modelling practices and more towards face based modelling, which is far more prone to crashing and intensive resource consumption.
Solved by johnsonshiue. Go to Solution.
Hello, could you attach an image of the behavior of the software? You are talking about Inv 2019. Grettings!
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank GOD.
Do people not use reference parameters? How does it ship like this?
Hi Andrew,
There was a design change to accommodate other controls in the Panel UI leading to this behavioral change. We did get negative feedback. We are actively working on a solution to change it back.
Many thanks!
Thanks Johnson,
I hope I don't sound like some on here that nitpick at every change, but this just seems too fundamental to tweak.
