Pack and Go Problem - Inventor 2017
Just upgraded to 2017 and while 1 user has no issues another can't pack and go as this is the error message they get.
So anyone out there that can tell me whats wrong and how I fix this?
Mark.Lancaster
@Anonymous
Welcome to the community..
This has popped up before in the past and nothing really solved it except for blah blah blah..  Smiley Very Happy
Here's what I would suggest if there's noting wrong with the model.. Can you confirm nothing is wrong with the model.
1.  Exit Inventor
2.  Select the Windows Start Button and type CMD in the search field but do not hit an enter.
3.  When command prompt appears in the list, right mouse click on it and select Run as Admin.
4.  In the command prompt navigate to C:\Program Files\Autodesk\Inventor 2017\Bin
5.  Type Inventor.exe /install
6.  Wait a few mins and then restart Inventor
Did that resolve the issue?
Mark Lancaster
mdavis22569
Also are you using a custom material property?
Make sure you also have all of your updates installed for 2017
https://knowledge.autodesk.com/support/inventor-products/downloads
Mike Davis
blair
Possibly there might be an issue with the IDW file. Open the file and do a "rebuild all" and save it. I've seen the occasional time were a IDW or IAM file is not "current" and the opening of the file allow Inventor to update all files related to the assembly and drawing solves the issue.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
While this did not directly solve the problem it did lead us to the solution. IT had to go in and redo my profile and now it works.
