Inventor Symbol Library mapped to local Design Data folder not shared network
Not sure what I might have setup incorrectly here, but the project file has the Design Data folder mapped to our share folder on the network, but when I create the shared symbol library it creates it in the local Design Data folder. I tried just cut/pasting the .idw file to the shared location, but opening the drawing it doesn't show up. Any ideas?
SBix26
Application Options > File > Sketch Symbol Library folder
Sam B
Inventor Professional 2017 R2
Vault Basic 2017
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
melvin.valverde.delgado
Hi bbuck
You can set the Sketch Symbol folder as was mentioned by sbixler, also, take in consideration that a command to Save All to Symbol Library is also an available option. To retain your folder structure (when transporting to a library), you can select the Retain Resource Folder Structure check box.
Melvin Valverde
Autodesk Technical Support
Greatwhitenorth
Is there a way to add the Symbol Library folder to an .ipj project file?  If so, where how would it be listed?
Thanks in advance,
Bob
__________________________________________________________
Product Design & Manufacturing Collection 2025 | Vault Professional 2025
Dell Precision 7670 | Intel i7-12850HX - 2100 Mhz - 64GB
nVIDIA RTX A3000 12GB | Windows 11 Pro
SBix26
There is not such an option as far as I know, but this Inventor Ideas forum post proposes exactly that, and could use some additional votes.
Sam B
Vault Basic 2017.0.1
Greatwhitenorth
I added my vote!  Thanks Sam!
Bob
