I thought in previous versions, when doing a positional overlay, only the items that have "changed position" have the broken lines. In IV2011, the whole model has the secondary overlay broken lines except for the base part that has the "Positional" in a different position.
Solved by blair. Go to Solution.
Reduce line width in Styles from 0.020 to 0.014 for the Overlay Line/Layer
In addition to these suggestions, if you make a View Rep with just the components that change position, you can use it in the overlay view, so you don't get the extra lines.
Thanks, I didn't think of doing it that way
