How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
I want to analyze the force in the linkage.
So I get into the dynamic simulation menu.
This is picture about error message. But it is in korean.
It says mechanism is 1 DOF overconstraint.
This is the error part.
I insert axis-constraint in each part
And the above assembly is connected to this part.
Cylinder and piston is connected as axis-constraint.
I attached my file
If you guys have any idea about this please give some comments.
Thank you
Try >>this<<.
(I didn't upload the files because I used IV 2020, you will not be able to read it).
Jürgen Palme
The part named Finger-base.ipt is missing from your zipped attachment?
Also, your part sketches are not fully defined - which is poor modeling practice.
And, you should install the Updates for 2019.
Thank you for your help
But I missed a part
So, I uploaded the missing part
Can you see it please?
Add, I attached what I want to simulate in video
Thank you for your reply
I'm sorry I started Inventor 2 weeks ago, so I'm the beginner
I installed the update
And I attached the video that shows what I want to simulate.
I want to get link's reaction force and how to move the linkage
Thank you for reading
This is an advanced topic.
Open the Attached assembly and run the Dynamic Simulation.
I really appreciate it.
It is very helpful for me !
Sir, I tried to follow your method.
But error still exist.
If you don't mind, could you give me a video or comment on the problem with my file?
Assembly for test ( behind ) is my assembly file
You can repair your assembly as shown >>here<<.
Jürgen Palme
How to buy
Type a product name
